arcpy file permission shutil copy
952
5
04-23-2021 07:51 AM
NatashaManzuiga
Hi all, I created a geoprocessing task and it perfectly works.
At the end I see that I have the same problem of this thread with arcgis server with linux:
https://community.esri.com/t5/python-questions/arcgis-server-on-linux-python-unable-to-change-file-p...
Does someone have the solution? Or I cant do anything to change the files permission from arcgis python?
Naty
JoeBorgione
What version of python are you using?
NatashaManzuiga
I'm using ArcGIS Enterprise 10.8 so I think:
  • Python 2.7.16, NumPy 1.9.3, and matplotlib 1.5.2
  • Python 3.6.9, NumPy 1.16.5, and matplotlib 3.1.1
Naty
DanPatterson
both python versions have the "os" module, just check their version of "os" for exact syntax
... sort of retired...
DanPatterson
MarkKinnaman
There are several ways to call chmod via python. You can use os.chmod() from os and you can use Path.chmod() from pathlib depending on personally preference. Also, if you only need to set the user permissions os and shutil have chown() functions.
OS Python Docs
Python Pathlib Docs
Shutil Docs
