arcpy AsciiToRaster cannot convert ascii files that contain a lot of 'nodata (-9999)'
2782
12
03-13-2021 01:56 PM
RYokochi
I have 570 ascii files with headers (example shown below). About 400 of them opens as ascii or I can convert to raster using arcpy 'AsciiToRaster'. But I have problem with coastal cells containing relatively large fraction of 'Nodata_value' cells.
I first thought it could be the format of nodata_values, but some files contain smaller number of nodata-values works, so this is probably not the case. The coastal cells I can open does not seem to have exact matching coastal line with the baseman. The coordinate system of the ascii data is JGD2011.
Anyone could advise what the problem is and how I could fix?
NCOLS 225
NROWS 150
XLLCORNER 130.3
YLLCORNER 32.675
CELLSIZE 5.555555333335368e-05
NODATA_VALUE -9999
RYokochi
Here is a summary so people get consolidated answers from the question without following the exchanges:
Why didn't arcpy convert my ascii file?: Because the number of data was insufficient for the given column x row
Why was the number of data insufficient?: Because a fraction of the data over the ocean was omitted. The original data in xml file did contain this information as 'start point' but I was not aware.
The ascii file was generated from an .xml file from Japanese database at https://fgd.gsi.go.jp/download/mapGis.php?tab=dem
Rather than translating these oneself, there two programs freely available [both also informed by Luke_Pinner]:
A software from: https://www.ecoris.co.jp/contents/demtool.html
A Python script from: https://gist.github.com/minorua/4993166.
I used the Python script to generate the map I wanted (attached).
Thank you, Luke_Pinner!!!
Luke_Pinner
MVP Regular Contributor
One more option which works with ArcGIS Pros arcgispro-py3 python environment
Save and run the fgddem.py script from https://gist.github.com/minorua/4993166.
D:\Temp\jpgis> activate arcgispro-py3
(arcgispro-py3) D:\Temp\jpgis> python fgddem.py
No input files selected
=== Usage ===
python fgddem.py [-replace_nodata_by_zero] [-f format] [-out_dir output_directory] [-q] [-v] src_files*
src_files: The source file name(s). JPGIS(GML) DEM zip/xml files.
(arcgispro-py3) PS D:\Temp\jpgis> python fgddem.py -f GTIFF -out_dir . FG-GML-4930-01-20-DEM5A-20161001.xml
translating FG-GML-4930-01-20-DEM5A-20161001.xml
completed
RYokochi
This is my favorite! Thank you again for the solution #3!
