ArcGIS 2.9 Pro Notebook failed Kernel
2103
6
12-22-2021 02:00 AM
RubenBM
I'm opening a new project  in ArcGIS pro , and when is loaded ,  i've found  that  there is a falied   to star the Kernel.
I'm triying to find a solution,  but   at this monoment i can't resolve it.
Here is the specific  error:
AttributeError: 'IOLoopKernelManager' object has no attribute 'kernel_cmd'
I´m triying to look for the failied   in the code but i can´t find  the  issue.
Somebody could help me  with the same or similar fail?.
Thanks !!.
DanPatterson
MVP Esteemed Contributor
version of Pro? and the arcgis module and its version?
... sort of retired...
RubenBM
Arcgis Pro 2.9, ArcgisPro NoteBoook,
DanPatterson
Windows add/remove programs, select Remove, then Repair.
If that doesn't work, and you are getting an error with a ... new .... empty...  Locally saved project ... and you open a notebook and get the error, then contact tech support since there is probably something in your environment .
If it is a specific project, try another.
If you don't need to see a mapped results, just use JupyterLab or Jupyter notebook outside of Pro.
RubenBM
Ok thanks , i'll try
AzinSharaf
Occasional Contributor II
i can't reproduce the error. Maybe a re-install will fix it.
my test was on ArcGIS Pro 2.9 and ArcGIS module 1.9.1.
IngridMans
I'm having this issue too; is there really no solution??
I'm getting:
*update* I have discovered this is only an issue on my cloned env, but not my default one. I would like to fix this for my clone env, since I like to use the one where I've modified to use spyder. Any suggestions for fixing the cloned env?
