Apply datum tranformation only if source datum is different than target
1901
10-22-2021 12:49 PM
ZacharyHart
Honored Contributor
I'm trying to create a simple evaluation within a script which does not restrict the spatial reference of the data, but the output is fixed: WGS 1983 Web Mercator Aux Sphere. All inputs will be projected data.
I want to project any input data to match the desired output projection, but I need to evaluate the datum of the input vs the output. .
Unfortunately, according to the documentation found here, this property (GCSName) is available only for geographic data. However:
Because a projected coordinate system is based on a geographic coordinate system, projected coordinate system properties can be accessed from a geographic coordinate system via the GCS property.
But the GCS property returns a spatial reference object for which I do not know how to format or parse parameters from to evaluate. Is there a way to do this? This will eventually be rolled-up into a script tool.
Any general tips on handling such a process would be greatly appreciated. I anticipate there will only be a handful of input PCS to deal with but it is entirely possible that there both NAD83 & WGS84 datums (3 feet matters for us in this case!).
DanPatterson
MVP Esteemed Contributor
for my example
sr.GCS
<geoprocessing spatial reference object at 0x243ed372af0>
sr.GCS.name
'GCS_North_American_1983'
instead of parsing the whole string
... sort of retired...
DanPatterson
in_fc = r"C:\Git_Dan\npgeom_bak\Project_npg\npgeom.gdb\Ontario_singlepart"
sr = arcpy.Describe(in_fc).spatialReference
sr.name
'NAD_1983_Statistics_Canada_Lambert'
sr.exportToString()
'PROJCS["NAD_1983_Statistics_Canada_Lambert",
        GEOGCS["GCS_North_American_1983",
        DATUM["D_North_American_1983",
        SPHEROID["GRS_1980",6378137.0,298.257222101]],
        PRIMEM["Greenwich",0.0],
        UNIT["Degree",0.0174532925199433]],
 PROJECTION["Lambert_Conformal_Conic"],
 PARAMETER["False_Easting",6200000.0],
 PARAMETER["False_Northing",3000000.0],
 PARAMETER["Central_Meridian",-91.86666666666666],
 PARAMETER["Standard_Parallel_1",49.0],
 PARAMETER["Standard_Parallel_2",77.0],
 PARAMETER["Latitude_Of_Origin",63.390675],
 UNIT["Meter",1.0]];-28455800 -28572600 10000;-100000 10000;-100000
 10000;0.001;0.001;0.001;IsHighPrecision'
There are easier ways to get at the information, but every projected coordinate system has a root GCS and hence a datum associated with (lines 9 and 10).  You just have to sift through the properties
SpatialReference—ArcGIS Pro | Documentation
ZacharyHart
Honored Contributor
Thanks Dan! That's the same doc I linked to as well. I'm able to generate the string, but are the items in the Spatial Reference object indexed so I can parse them out? Are they keyed? The documentation isn't very detailed.
Thanks again, you do so much for us!
DanPatterson
for my example
sr.GCS
sr.GCS.name
ZacharyHart
Honored Contributor
that works, thanks!! i'm off to the races now.
