I need a method to upload roughly 2,000 PDF's into a specific folder in my content (and share to public)
All PDF's will be inside the same directory on a network drive.
I assume python can handle this but not sure, I see I can upload a geodata (shapefile, layer, map etc.) but not positive about images/PDF's.
I was able to do this utilizing the Python API, the code is below for anyone else who may need this in the future
import arcgis
from arcgis.gis import *
import os
import glob
import timegis = GIS(None, "username", "password")
contentManager = arcgis.gis.ContentManager(gis)
contentManager.create_folder('Folder Name',None)
pdf_list = glob.glob(r'C:\path\to\folder\*.pdf')
additem = arcgis.gis.ContentManager(gis)
for pdf in pdf_list:
file_name = os.path.basename(pdf)
pdf_properties = {'type':'PDF','title':file_name.split(".")[0],'tags':'pdf, arcgis,', 'access':'Public'}
additem.add(pdf_properties,pdf,folder='Historic PDFs')
time.sleep(1)
item_search = gis.content.search(query='', item_type='PDF')
item_search
for item in item_search:
item.share(everyone=True)
time.sleep(1)
I had to use the
time.sleep(1)
otherwise updating the share properties would skip some of the files, I am guessing the calls were being sent to fast for the server to pick up.
The easiest way to upload files is the requests module:
Post a multi-part encoded file
It's far easier than the urllib2 modules:
Make an http POST request to upload a file using python urllib/urllib2 - Stack Overflow
What I typically do is run through the operation through your browser first and monitor the network traffic. After that, recreate the request in Python.
Something like this would likely work:
addItemURL = 'https://<portal>.<domain>.com/portal/sharing/rest/content/users/<user>/addItem'
item = '<path to item>'
uploadFile = open(item,"rb")
theFile = {'file':uploadFile}
data = dict(token=<token>,type=.....) #not sure about what parameters are used for uploading a PDF. My suggestion above will come in handy here)
r = requests.post(addItemURL, params=data, files=theFile, verify=False) #verify=False ignores certificate errors
addItemResponse = json.loads(r.text)
print(addItemResponse)
Once you upload an individual item, just loop through your directory using os.walk or os.listdir.
15.1. os — Miscellaneous operating system interfaces — Python 2.7.15 documentation
import arcgis
import os
import glob
time.sleep(1)
item_search
time.sleep(1)
I had to use the
time.sleep(1)
This appears to be just for AGO, do you know how I could modify the gis=GIS() connector string for ArcGIS Enterprise Portal?
See arcgis.gis module - GIS — arcgis 1.5.0 documentation:
Argument Description url Optional string. If URL is None, then the URL will be ArcGIS Online. This should be a web address to either a local Portal or to ArcGIS Online in the form: <scheme>://<fully_qualified_domain_name>/<web_adaptor> (Portal Example)https://gis.example.com/portal
I want to publish 30 pdfs to Arcgis Online, I use the same code but i want to modifiy the propreties like this :
Name of one of my pdfs : Map_community_A3_TEST_61001
Template : ([DOCUMENT_TYPE]_[OBJECT]_[FORMAT]_[NAME]_[CODE])
I want to modifiy pdf_propreties from
pdf_propreties = {'type':'PDF', 'description':'PDF upload for map viewer','title':pdf_name, 'tags':'OPENDATA', 'access':'Public'}
To :
pdf_propreties = {'type':'PDF', 'description':'DOCUMENT_TYPE, FORMAT, NAME','title':NAME, 'tags':'DOCUMENT_TYPE, FORMAT, NAME, CODE', 'access':'Public'}
Do u think there's a way to do it ?
Thank you 🙂
Thanks for posting - this will be helpful!
Very useful information… I am trying to do the same but instead of uploading, I am trying to update the PDF files that are inside a specific folder. Can someone point me to the right direction?
