Allow passing in client id parameter to the arcpy.management.SharePackage tool to authenticate to a portal that uses OAUTH2.
739
03-28-2021 11:50 PM
Status: Open
AndresCastillo
MVP Regular Contributor
As per:
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/share-package.htm
This capability is not available as of ArcGIS Pro 2.7
This would be nice to have for custom scripts  outside of ArcGIS apps that create some type of package, then want to share it to an OAUTH2 portal, such as ArcGIS Online
1 Comment
KoryKramer
Hi @AndresCastillo
If you have saved your credentials in Pro using “Sign me in automatically”, does it make it so standalone Python can act against the same portal?
This was tested on our side - signed into Pro, click that box to save credentials for the active portal, AGOL. Closed Pro. Opened Python. Ran Share Package. It works.
Can you try that and let us know what you find?
Thanks
