2. Python API authentication with SAML
1157
04-07-2021 10:51 AM
Status: Open
ctsung_uscssi
New Contributor II
The ArcGIS Online enterprise sign-in, in our case ADFS, is not supported by ArcGIS API for Python, this has been identified as a bug and enhancement back in 2/23/2017 ENH-000103131. This is problematic because if an enterprise user wishes to schedule to run a task periodically, this can't be accomplished with the enterprise sign-in.
Similar issue was also reported and discussed in Geonet (https://community.esri.com/t5/arcgis-api-for-python-questions/is-it-possible-to-use-the-arcgis-onlin...), but the suggested solution by Rohit would not work because it would still need the user to enter the AppID interactively.
2 Comments
by Anonymous User
Just a note to say that you will be able to setup Notebook tasks with the next release of ArcGIS Online meaning the script gets run on a schedule. Through that the gis = GIS('home') login option can be used to login.
It doesn't fix the problem you're encountering but it may help in some cases.
ctsung_uscssi
Thank you Michael, looking forward testing the new release.
