Point Tools for Pro
1938
5
05-14-2020 07:18 PM
DanPatterson
3 5 1,938
Reincarnation as myself since being "retired" from my organization.  Published earlier, but with updates.
Download the zip.  Unzip into a folder.  Load the toolbox.
Alter
  • Options to move/translate/shift points to a new location using delta X and Y values
  • Rotate points as a whole about their centroid.
  • Sort points by coordinate options
  • Radial sort (aka, angle about the point centroid)
Analysis
  • Closest/near analysis
    • between layers
    • within layers
    • with a table
  • Concave and convex hulls. Yes, available without an Advanced license
  • Spanning tree.... connect points by polylines, representing the shortest path to connect them all.  Everyone loves a tree
  • Standard Distance, similar to standard deviational ellipse, except for the circle
  • Triangulation tools.  Voronoi, Delaunay space delineation.  No 3D analyst?  No problem, you can do it now.
Creation
  • Circle points.  Because you can.
  • Mesh points.  Nothing like points in a rectilinear pattern
  • Spaced Points.  Got to keep your distance?  Space points so that no point is closer than a certain value.
5 Comments
ZeldaEls
Very nice. Thank you, Dan.
AshtonWoodrow1
Awesome toolbox Dan. Thank you!
CGoetsch
Dan,
I am running into a problem installing this toolbox. When I add the toolbox to ArcGIS, it shows up but without a dropdown menu for the actual tools. I haven't encountered this problem before and am not sure what I am doing wrong.
mlopezr95984
Thank you, Dan! This is a very useful tool.
EricBushee
Thanks, Dan. These are great. Any chance the voronoi polygons could bring along the attributes of the points? That would save a second step of a spatial join.
About the Author
Retired Geomatics Instructor (also DanPatterson_Retired). Currently working on geometry projects (various) as they relate to GIS and spatial analysis. I use NumPy, python and kin and interface with ArcGIS Pro.
Labels
