Last month a user mentioned the Dijkstra algorithm to determine the shortest path between two nodes in a network. My first reaction was to use Network Analyst instead, but to honor the essence of a previous useless post: Japanese visual multiplication with lines using arcpy and a dash of patriotism (Dijkstra was Dutch) made me look into this a little more.
I came across this post; Dijkstra's algorithm for shortest paths « Python recipes « ActiveState Code and from this post I actually used the code from this one; Rebrained! » Blog Archive » Shortest Path – Python . Remember, basic skills for developing code are search, copy and paste…
It is basically recursive code that will ultimately get you the route between two nodes on the network. What you need is a "graph". This is a nested dictionary that lists all the connections between the from and to nodes and the corresponding distances. To be able to use the code I need to convert my "network" into this graph format.
What you need is a network (a simple line featureclass), in which all intersections of lines consist of nodes. You will also need a point feature class containing the start and end point. These points should correspond with nodes of the network.This is the result:
I came up with the following code:
#------------------------------------------------------------------------------- # Name: dijkstra.py # Purpose: determine route # # Author: xbakker # # Created: 02/12/2014 #------------------------------------------------------------------------------- import arcpy import sys def main(): # input featureclasses fc_red = r"D:\Xander\GeoNet\Dijkstra\fgdb\test.gdb\red" fc_stops = r"D:\Xander\GeoNet\Dijkstra\fgdb\test.gdb\stops2" # create line dictionary dct_lines = createLineDict(fc_red) # create node and inverted node dictionary dct_nodes = createNodes(dct_lines) # update line dictionary with nodes dct_lines_nodes = combineLinesAndNodes(dct_lines, dct_nodes) # create graph dct_graph = createGraph(dct_nodes, dct_lines_nodes) # determine the node of start and end of route node_start, node_end = getStartEndNodes(fc_stops, dct_nodes) # determine route result = shortestpath(dct_graph, node_start, node_end) # create line with the result dist = result[0] route = result[1] print "Resulting route : {0}".format(route) print "Length of the route: {0}\n".format(dist) cnt = 0 for node_id in route: cnt += 1 print "{0}\t{1}\t{2}".format(cnt, dct_nodes[node_id][0], dct_nodes[node_id][1]) def createLineDict(fc): """Crear dict de lineas con datos relevantes""" #OBJECTID (line): length, (Xstart, Ystart), (Xend, Yend) dct_lines = {} flds = ("OID@", "SHAPE@", "SHAPE@LENGTH") dct_lines = {r[0]: [r[2], (r[1].firstPoint.X, r[1].firstPoint.Y), (r[1].lastPoint.X, r[1].lastPoint.Y)] for r in arcpy.da.SearchCursor(fc, flds)} return dct_lines def createNodes(dct): """Crear dict de nodos""" node_format = "node_{0}" cnt = 0 dct_nodes = {} dct_nodes_inv = {} for line in dct.values(): start = line[1] if not start in dct_nodes.values(): cnt += 1 node_id = node_format.format(cnt) dct_nodes[node_id] = start end = line[2] if not end in dct_nodes.values(): cnt += 1 node_id = node_format.format(cnt) dct_nodes[node_id] = end return dct_nodes def combineLinesAndNodes(dct_lines, dct_nodes): """Crear dict con lineas y codigo de nodos""" dct_lines_nodes = {} for oid, line in dct_lines.items(): start = getNodeID(line[1], dct_nodes) end = getNodeID(line[2], dct_nodes) dct_lines_nodes[oid] = [line[0], start, end] return dct_lines_nodes def getNodeID(pnt, dct_nodes): for node_id, coords in dct_nodes.items(): if coords == pnt: return node_id break def createGraph(dct_nodes, dct_lines_nodes): res = {} for node_id in dct_nodes.keys(): links = {} nodes_start = [[line[2], line[0]] for line in dct_lines_nodes.values() if line[1] == node_id] for node in nodes_start: links[node[0]] = node[1] nodes_end = [[line[1], line[0]] for line in dct_lines_nodes.values() if line[2] == node_id] for node in nodes_end: links[node[0]] = node[1] res[node_id] = links return res def getStartEndNodes(fc, dct_nodes): cnt = 0 with arcpy.da.SearchCursor(fc, ("SHAPE@")) as curs: for row in curs: cnt += 1 if cnt == 1: pnt = row[0].firstPoint node_start = (pnt.X, pnt.Y) node_start = getNodeID(node_start, dct_nodes) elif cnt == 2: pnt = row[0].lastPoint node_end = (pnt.X, pnt.Y) node_end = getNodeID(node_end, dct_nodes) else: break return node_start, node_end def shortestpath(graph,start,end,visited=[],distances={},predecessors={}): """Find the shortest path between start and end nodes in a graph""" # we've found our end node, now find the path to it, and return if start==end: path=[] while end != None: path.append(end) end=predecessors.get(end,None) return distances[start], path[::-1] # detect if it's the first time through, set current distance to zero if not visited: distances[start]=0 # process neighbors as per algorithm, keep track of predecessors for neighbor in graph[start]: if neighbor not in visited: neighbordist = distances.get(neighbor,sys.maxint) tentativedist = distances[start] + graph[start][neighbor] if tentativedist < neighbordist: distances[neighbor] = tentativedist predecessors[neighbor]=start # neighbors processed, now mark the current node as visited visited.append(start) # finds the closest unvisited node to the start unvisiteds = dict((k, distances.get(k,sys.maxint)) for k in graph if k not in visited) closestnode = min(unvisiteds, key=unvisiteds.get) # now we can take the closest node and recurse, making it current return shortestpath(graph,closestnode,end,visited,distances,predecessors) if __name__ == '__main__': main()
Have fun!
