Publish an exisiting cache as a map service
212
08-03-2020 01:29 PM
DavidPike
MVP Frequent Contributor
Hi all,
ArcMap 10.5.1, Server 10.6.1.  No image server extension.
I have a cache of imagery with cache levels going from a scale of roughly 1:300 and cell size increasing by 2^n.
The cache is post 10.3 and in bundlex format.
Some very noob questions, but have always bothered me:
1. If an image is published and cached on the server at all appropriate levels, my understanding is the base image would never be drawn - i.e. cached tiles would always be pulled instead?
2. cached levels at 2^n are most appropriate from a mathematical perspective, the only reason these may differ is that the cache is intended to be used in a viewer with set scales, whereby the exact resolution eg 1:50,000 can be fetched. Is this a correct assumption?
3. How can I publish just from my cache without the original tile?  (I have the tiling scheme) Can I just publish any raster (with correct spatial reference) and hide it behind the cache? Would that raster need to have at-least the same extent of the cache? Is there a better way of doing it?
Thanks very much.
