The Esri Tech blog on GDA2020 https://esriaustraliatechblog.wordpress.com/2018/12/24/understanding-gda2020-and-its-relationship-wi... recommends>
On point 3. Create your own basemaps in GDA2020 - has anybody done this and also successfully published as a WMTS? Is this even possible as default cache method is WGS84? Is this recommendation implying using the method GDA2020>WGS84 using null projection (EPSG:8450). As a side note customers using Geocortex require services to be published in the same datum as their basemap datums so the getcaps would need to specify GDA2020.
P.S a dedicated GDA2020 section in communities would be great 🙂 Kylie
Hi Kylie,
While, I have not come across that workflow before, I can address some of the points that you raised. You are correct in that by default, tile caches use the Web Mercator/WGS84 projection. If you would like to cache your data using a different projection, you will have to use the Generate Tile cache Tiling Scheme geoprocessing tool. this allows you to specify scales and coordinate system, among other parameters
Then, when caching your service, import the XML file that was created from running the tool, and the cache will be built according to your specifications.
Hope this helps!
-Calvin
Hello Kylie,
Creating your own basemap in GDA2020 (Projected or geographical) will mean that you need to
1) Define your own tiling scheme for that basemap. Yes this is different to the global basemaps as they are all in WGS84 Web Mercator Auxiliary Sphere. The traditional tiling scheme for the global basemaps is defined if you choose the ArcGIS Online tiling scheme. (Generate Tile Cache Tiling Scheme)
2) Use this tiling scheme as the definition for your basemaps. (Manage Tile Cache).
NOTE: I would consider using Vector Tile Packages as they are more efficient and faster to create and update.
3) Package the tile cache for loading to ArcGIS Online or ArcGIS Enterprise by using the Export Tile cache tool
4) Once you have this basemap package then you publish to ArcGIS Online or ArcGIS Enterprise using the Share tools
5) You can use this as you basemap but everything you place on-top of it now will be projected to GDA2020. You cannot add other global basemaps behind as they are in WGS84 Web Mercator Auxiliary Sphere but the map will be in GDA2020.
6) From this you should be able to add the WMS capability (Which includes the WMTS for cached basemaps).
Also good suggestion on the GeoNet for creating a GDA2020 discussion group I will look into this
Cheers
Gordon
Hi Kylie,
Hope this helps!
-Calvin
So you would need to use ArcGIS Pro then? We are not currently using Pro to publish our data as it's not integrated into our architecture yet.
Hi Kylie,
The same tool also exists in ArcGIS Desktop.
Here is a technical article outlining this workflow:
https://support.esri.com/en/technical-article/000012213
Best,
Calvin
Hello Kylie,
Cheers
Gordon
