Failed to Publish a Geocode Service to ArcGIS Enterprise 10.6.1
1389
02-04-2021 11:31 AM
EmilyL
Hello,
I'm trying to publish a simple (Gazetteer) geocode service to the server (ArcGIS Enterprise 10.6.1), but it says "Failed to publish service" without anymore information.  In the past I was able to publish in the same way without any issue.  Publishing other map/feature services are fine.  Checked the ArcGIS Server logs, but didn't see any warnings/errors, not even a trace of trying to publish.  What should I check next?
Thank you,
Emily
by Anonymous User
Not applicable
Hi Emily,
Is this a single address locator, or are you publishing a composite locator?
Do other locator styles (e.g. Single House) publish successfully? Or is it just Gazetteer?
Are you trying to copy the locator onto the Server machine, or reference it from a registered folder?
-Calvin
EmilyL
Hi Calvin,
Thanks for your reply.
It's a single locator, not composite.
I've tried both Single Field and Gazetteer geocoder. Both failed.
I'm trying to copy the locator to the server.
Thank you,
Emily
by Anonymous User
Not applicable
Hello Emily,
Can you publish any service to ArcGIS Server from your desktop? For example, are you able to publish a simple feature class as a map service successfully? This will help narrow down potential issues.
-Calvin
EmilyL
Hi Calvin,
Yes, publishing any other feature/map services to the server is fine.
Emily
EmilyLee2
New Contributor III
Problem solved!  I was able to overwrite the geocode service using ArcGIS Pro 2.7.  Not sure why it didn't work from ArcGIS 10.7.1.  Anyway, it's good now.  Thanks a lot!
Emily
