Publishing a geoprocessing service fails in 10.8.1
1082
10-30-2022 05:17 AM
sxj
New Contributor II
I am trying to publish a geoprocessing service, but it fails.
Both ArcGIS Enterprise (10.8.1) and ArcGIS Desktop (10.8.1) are on the same machine
The output of the results window in ArcGIS Desktop shows this:
Stage Service - Passes
Upload Service Definition - Failed
Results WindowResults Window
The logs from server show the following:
Error Code=9999 - java.rmi.UnmarshalException: Error unmarshaling return header
<Msg time="2022-10-30T12:51:25,570" type="INFO" code="9526" source="Soap" process="6772" thread="20" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="f5fc75cf-b5ce-4c6b-b33e-34fa08a6d7fd">Request for the service 'System/PublishingTools.GPServer' processed successfully. Response sent to the user '0123456789ABCDEF::myname'.</Msg>
<Msg time="2022-10-30T12:51:25,570" type="DEBUG" code="9999" source="Server" process="6772" thread="27" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="f5fc75cf-b5ce-4c6b-b33e-34fa08a6d7fd">Server object processing time for service request: System.PublishingTools.GPServer is 5 ms.</Msg>
<Msg time="2022-10-30T12:51:25,716" type="SEVERE" code="7551" source="Server" process="6772" thread="27" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="e08dc073-bd06-4d5d-87fa-889601fa35ea">Instance of the service 'System/PublishingTools.GPServer' crashed. Please see if an error report was generated in 'C:\arcgis\arcgisserver\logs\MACHINEACTUALNAME\errorreports'. To send an error report to Esri, compose an e-mail to ArcGISErrorReport@esri.com and attach the error report file.</Msg>
<Msg time="2022-10-30T12:51:25,717" type="DEBUG" code="9999" source="Server" process="6772" thread="27" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="e08dc073-bd06-4d5d-87fa-889601fa35ea">java.rmi.UnmarshalException: Error unmarshaling return header; nested exception is:
	java.net.SocketException: Connection reset
	at java.rmi/sun.rmi.transport.StreamRemoteCall.executeCall(Unknown Source)
	at java.rmi/sun.rmi.server.UnicastRef.invoke(Unknown Source)
	at java.rmi/java.rmi.server.RemoteObjectInvocationHandler.invokeRemoteMethod(Unknown Source)
	at java.rmi/java.rmi.server.RemoteObjectInvocationHandler.invoke(Unknown Source)
	at com.sun.proxy.$Proxy18.handleRequest(Unknown Source)
	at com.esri.arcgis.discovery.admin.rediscovery.service.ArcSOCGISService.handleRequest(ArcSOCGISService.java:598)
	at com.esri.arcgis.discovery.admin.rediscovery.actors.GPServerObjectSyncActor.onReceive(GPServerObjectSyncActor.java:156)
	at akka.actor.UntypedActor$$anonfun$receive$1.applyOrElse(UntypedActor.scala:167)
	at akka.actor.Actor$class.aroundReceive(Actor.scala:467)
	at akka.actor.UntypedActor.aroundReceive(UntypedActor.scala:97)
	at akka.actor.ActorCell.receiveMessage(ActorCell.scala:516)
	at akka.actor.ActorCell.invoke(ActorCell.scala:487)
	at akka.dispatch.Mailbox.processMailbox(Mailbox.scala:238)
	at akka.dispatch.Mailbox.run(Mailbox.scala:220)
	at akka.dispatch.ForkJoinExecutorConfigurator$AkkaForkJoinTask.exec(AbstractDispatcher.scala:397)
	at scala.concurrent.forkjoin.ForkJoinTask.doExec(ForkJoinTask.java:260)
	at scala.concurrent.forkjoin.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:1339)
	at scala.concurrent.forkjoin.ForkJoinPool.runWorker(ForkJoinPool.java:1979)
	at scala.concurrent.forkjoin.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:107)
Caused by: java.net.SocketException: Connection reset
	at java.base/java.net.SocketInputStream.read(Unknown Source)
	at java.base/java.io.BufferedInputStream.fill(Unknown Source)
	at java.base/java.io.BufferedInputStream.read(Unknown Source)
	at java.base/java.io.DataInputStream.readByte(Unknown Source)
	... 19 more
</Msg>
Error Code=9999 - java.rmi.UnmarshalException: Connection refused to host: localhost
<Msg time="2022-10-30T12:51:26,603" type="INFO" code="9526" source="Soap" process="6772" thread="20" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="671d635e-df81-4f91-aed9-68f359ce9a11">Request for the service 'System/PublishingTools.GPServer' processed successfully. Response sent to the user '0123456789ABCDEF::myname'.</Msg>
<Msg time="2022-10-30T12:51:26,602" type="DEBUG" code="9999" source="Server" process="6772" thread="27" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="671d635e-df81-4f91-aed9-68f359ce9a11">Server object processing time for service request: System.PublishingTools.GPServer is 6 ms.</Msg>
<Msg time="2022-10-30T12:51:26,720" type="DEBUG" code="9999" source="Server" process="6772" thread="27" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="e08dc073-bd06-4d5d-87fa-889601fa35ea">java.rmi.ConnectException: Connection refused to host: localhost; nested exception is:
	java.net.ConnectException: Connection refused: connect
	at java.rmi/sun.rmi.transport.tcp.TCPEndpoint.newSocket(Unknown Source)
	at java.rmi/sun.rmi.transport.tcp.TCPChannel.createConnection(Unknown Source)
	at java.rmi/sun.rmi.transport.tcp.TCPChannel.newConnection(Unknown Source)
	at com.sun.proxy.$Proxy18.shutdown(Unknown Source)
	at com.esri.arcgis.discovery.admin.rediscovery.service.ArcSOCGISService.stop(ArcSOCGISService.java:498)
	at com.esri.arcgis.discovery.admin.rediscovery.service.ArcSOCGISService.start(ArcSOCGISService.java:282)
	at com.esri.arcgis.discovery.admin.rediscovery.service.ArcSOCGISService.handleRequest(ArcSOCGISService.java:661)
Caused by: java.net.ConnectException: Connection refused: connect
	at java.base/java.net.PlainSocketImpl.connect0(Native Method)
	at java.base/java.net.PlainSocketImpl.socketConnect(Unknown Source)
	at java.base/java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
	at java.base/java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
	at java.base/java.net.AbstractPlainSocketImpl.connect(Unknown Source)
	at java.base/java.net.SocksSocketImpl.connect(Unknown Source)
	at java.base/java.net.Socket.connect(Unknown Source)
	at java.base/java.net.Socket.&lt;init&gt;(Unknown Source)
	at java.rmi/sun.rmi.transport.tcp.TCPDirectSocketFactory.createSocket(Unknown Source)
	... 23 more
</Msg>
<Msg time="2022-10-30T12:51:26,720" type="DEBUG" code="9999" source="Server" process="6772" thread="27" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="e08dc073-bd06-4d5d-87fa-889601fa35ea">Shutting down context for service: System.PublishingTools.GPServer</Msg>
<Msg time="2022-10-30T12:51:26,720" type="DEBUG" code="9999" source="Server" process="6772" thread="27" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="e08dc073-bd06-4d5d-87fa-889601fa35ea">Cleanup: Terminating SOC process. System.PublishingTools.GPServer</Msg>
Error Code=9999 - java.lang.Exception: Could not service request
<Msg time="2022-10-30T12:51:37,977" type="INFO" code="9526" source="Soap" process="6772" thread="20" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="86b57c7d-a9da-49d0-be34-e529e617d4cb">Request for the service 'System/PublishingTools.GPServer' processed successfully. Response sent to the user '0123456789ABCDEF::myname'.</Msg>
<Msg time="2022-10-30T12:51:38,748" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="34100" thread="22" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="e08dc073-bd06-4d5d-87fa-889601fa35ea">End server object construction. CLSID = {a6da33b7-4804-4116-b54d-a72d77dd4081}</Msg>
<Msg time="2022-10-30T12:51:38,748" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="34100" thread="22" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="e08dc073-bd06-4d5d-87fa-889601fa35ea">Server object implements IObjectActivate.</Msg>
<Msg time="2022-10-30T12:51:38,749" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="34100" thread="22" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="e08dc073-bd06-4d5d-87fa-889601fa35ea">Server object implements IRequestHandler2.</Msg>
<Msg time="2022-10-30T12:51:38,749" type="INFO" code="8000" source="System/PublishingTools.GPServer" process="34100" thread="22" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="7621.0" requestID="e08dc073-bd06-4d5d-87fa-889601fa35ea">Instance of service 'System/PublishingTools' has been created successfully.</Msg>
<Msg time="2022-10-30T12:51:38,806" type="DEBUG" code="9999" source="Server" process="6772" thread="27" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="e08dc073-bd06-4d5d-87fa-889601fa35ea"> Exception in com.esri.arcgis.discovery.admin.rediscovery.actors.GPServerObjectSyncActorcom.esri.arcgis.discovery.admin.rediscovery.util.ArcGISServiceException: Could not service request.</Msg>
<Msg time="2022-10-30T12:51:38,806" type="DEBUG" code="9999" source="Server" process="6772" thread="27" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="e08dc073-bd06-4d5d-87fa-889601fa35ea">java.lang.Exception: Could not service request.
	at com.esri.arcgis.discovery.admin.rediscovery.actors.RediscoveryAppServer.handleRequestNoWait(RediscoveryAppServer.java:466)
	at com.esri.arcgis.discovery.admin.rediscovery.actors.GPJobExecutorSingleton.a(GPJobExecutorSingleton.java:327)
	at com.esri.arcgis.discovery.admin.rediscovery.actors.GPJobExecutorSingleton.access$1300(GPJobExecutorSingleton.java:68)
	at com.esri.arcgis.discovery.admin.rediscovery.actors.GPJobExecutorSingleton$ExecutorThread.run(GPJobExecutorSingleton.java:520)
</Msg>
<Msg time="2022-10-30T12:51:38,806" type="DEBUG" code="9999" source="Server" process="6772" thread="27" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="e08dc073-bd06-4d5d-87fa-889601fa35ea">Exception caught while handling request for service -System/PublishingTools.</Msg>
<Msg time="2022-10-30T12:51:38,806" type="DEBUG" code="9999" source="Server" process="6772" thread="27" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="e08dc073-bd06-4d5d-87fa-889601fa35ea">java.lang.Exception: Could not service request.</Msg>
<Msg time="2022-10-30T12:51:38,806" type="SEVERE" code="7553" source="Server" process="6772" thread="27" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="e08dc073-bd06-4d5d-87fa-889601fa35ea">The containing process for 'System/PublishingTools' job 'j9abdea8d57b94ac2b2413cda4a482d9b' has crashed.</Msg>
<Msg time="2022-10-30T12:51:38,819" type="VERBOSE" code="7718" source="Server" process="6772" thread="27" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="e08dc073-bd06-4d5d-87fa-889601fa35ea">Job 'j9abdea8d57b94ac2b2413cda4a482d9b' for service 'System/PublishingTools' completed its execution. The status of the job after completion was 'esriJobFailed'. Elapsed time '87419' ms.</Msg>
<Msg time="2022-10-30T12:51:38,982" type="DEBUG" code="8521" source="Server" process="6772" thread="27" methodName="WebSecurityManager.authenticate" machine="MACHINEACTUALNAME" user="0123456789ABCDEF::myname" elapsed="" requestID="d886a6f7-46c3-442a-a15b-fcfb936787a2">HTTP Referer: http://www.esri.com/90370070-030B-49AD-BE5F-CF058F651497</Msg>
<Msg time="2022-10-30T12:51:38,982" type="INFO" code="9502" source="Soap" process="6772" thread="20" methodName="" machine="MACHINEACTUALNAME" user="0123456789ABCDEF::myname" elapsed="" requestID="d886a6f7-46c3-442a-a15b-fcfb936787a2">Request received from the user '0123456789ABCDEF::myname' for the service 'System/PublishingTools.GPServer'.</Msg>
<Msg time="2022-10-30T12:51:38,982" type="DEBUG" code="9999" source="Server" process="6772" thread="27" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="d886a6f7-46c3-442a-a15b-fcfb936787a2">RediscoveryAppServer handleRequest called. FQSN: System.PublishingTools.GPServer</Msg>
<Msg time="2022-10-30T12:51:38,982" type="DEBUG" code="9999" source="Soap" process="6772" thread="20" methodName="" machine="MACHINEACTUALNAME" user="" elapsed="" requestID="d886a6f7-46c3-442a-a15b-fcfb936787a2">Binary request for service - System/PublishingTools.GPServer</Msg>
I have tried a number of solutions but I am unable to resolve this issue. Any pointer are welcomed.
GlenShepherd
Hi @sxj ,
Does the same issue occur when attempting to publish a feature service or any other type of service?
Have we made sure that the 'publishingtools' and 'publishingtoolsex' system services are running on ArcGIS Server? And have we attempted restarting them?
sxj
New Contributor II
Hi @GlenShepherd
Publish feature services work and do not have other services besides this geoprocessing service I am trying to publish.
I have restarted the 'publishingtools' and 'publishingtoolsex' system services and they are also running.
I have also restarted arcgis service.
I have also rebooted the box.
The issue still occurs.
Thanks.
sxj
New Contributor II
Hi @GlenShepherd
I published the tool again this morning and it succeeded.
Not sure why, but what I did was to give it a new name when staging like defaultname_1 instead of defaultname and then uploaded defaultname_1.
GlenShepherd
Glad to hear it's working now, albeit under a different name...
I might recommend using ArcGIS Pro to carry out this workflow in the future and you may get some more descriptive troubleshooting messages from the desktop side if there is a failure.  To hazard a guess, it seems like some content has been created during the initial publishing stage and occupied the service name 'default' preventing you from creating another service by the same name...
