How to create an Image Service (ArcGIS Server) and its corresponding Imagery Layer (ArcGIS Portal) using the arcgis Python module
245
08-04-2025 12:23 PM
lmotta_ibama
Using ArcPy, I’m able to create an Image Service on ArcGIS Server and its corresponding Imagery Layer on the ArcGIS Portal, without requiring an Image Server license, by publishing a GeoTIFF with copy data to server enabled (ArcGIS Server).
I would like to know if it's possible to perform the same procedure using the arcgis Python module, without needing the Image Server license.
I appreciate in advance anyone who can help.
Priya_Das
Hi @lmotta_ibama
Without an Image Server license, if you're publishing to a federated ArcGIS Server with copy data to server enabled but you cannot -
  • You cannot publish dynamic image services (Mosaic data), -
  • You cannot overwrite or update imagery layers using advanced raster functions, You cannot use raster analytics or distributed processing.
  • Cannot use raster analytics
