Copy GDB failing in Web Tool
477
06-29-2022 08:10 AM
MOlesberg
I made a script for my organization which copies entire GDB files to new locations using UNC paths. The script functions successfully in ArcGIS Pro in the desktop toolbox. I shared the script as a web tool, and the copy function now receive the "Error 000260: Failed to copy" and "Error 999999: Something unexpected caused the tool to fail" with the same parameters.
The line which fails is arcpy.management.Copy(GDB, newGDBpath).
TonyContreras_Frisco_TX
Does the account that was set up as the ArcGIS Server service account have write access to the UNC location? How large are these FIle GDBs?
MOlesberg
The ArcGIS Server service account does have write access to the UNC location? The GDBs are large: 5-15 gigs depending on the mix of rasters, vector data, and attachments.
