BUG-000158848 A tile layer with a label in Chinese font is not displayed in Portal for ArcGIS Map Viewer.
731
05-26-2024 11:21 PM
xingchenc
Any update on this bug? Status says still in review.
BUG-000158848 for Portal for ArcGIS (esri.com)
Is there anyway to accelerate the process?
DanPatterson
MVP Esteemed Contributor
"Get bug updates in the app"  which used to be "Subscribe"
will add an additional count to the bug perhaps expediting its closure.  If a bug remains at a low count it doesn't move up on the "to fix" list quickly, especially since there is a workaround
... sort of retired...
xingchenc
Thanks for the tip!
Just want to point out that this suggested workaround is not exactly a good one, because it requires admin to modify the folder name in the arcgis server folder, which is not a real solution on user's end.
George_Thompson
Esri Notable Contributor
If you are already attached to this defect in My Esri, you can submit a defect escalation request.
If not attached, then you will need to work with support to get your account attached, then you can escalate via My Esri.
--- George T.
