All StopConnectors length value of 0, do not show up on map
1170
11-21-2019 12:39 PM
HelenaBreuer
New Contributor III
I ran Connect Network Dataset Transit Sources to Streets and the output created two layers, StopsOnStreets and StopConnectors.
I selected "Streets" for my features in the function input, and when I ran the function, the StopOnStreets remain located on LineVariantElements, and all StopConnectors have a length value of 0.
It appears that the function is treating the LineVariantElements as the Streets? Because it's producing StopsOnStreets, and all respective StopConnectors.
... any idea of how to fix? or what could have gone wrong?
I've attached the function parameters before I run it and two images of the output and attribute table
HelenaBreuer
New Contributor III
I figured it out - I had to add a clause to the original one in the tutorial. The clause I added said: or RestrictedPedestrians is null.
HelenaBreuer
New Contributor III
DavidPerlmutter
New Contributor II
Thank you, Helena! I just ran into the same problem.
