Repeat and near repeat classification tool - visualize connections feature class in 3D?
214
06-27-2020 08:02 AM
Repeat and near repeat classification tool (Crime analysis toolbox) creates line feature class representing relationship between repeat and near repeat incidents and their originators. I would like to visualize this in 3D but in the output of connections feature class  there is no Z values from corresponding repeats/near repeats and originators. How to visualize those lines n 3D together with R/NR/originators points? Help file states that the output is Z-enabled line feature, but it is not. Thanks!
Tags (1)
Reply
Nex Milkov
I reviewed the logic of Repeat and Near Repeat Classification tool, and the output lines are set to write to a feature class with Z Enabled:
The output points do write to feature class that is NOT Z Enabled, but it does write a "ZVALUE" attribute.
Here is an example of Elevation Layer Properties to visualize the points in a 3D scene:
Here is an example of Elevation Layer Properties to visualize the lines in a 3D scene:
With this combination you can achieve visualizations like this:
If the tool is creating output line features that are NOT Z Enabled as you've indicated then that is an unexpected behavior and we might need to take a look at the original input point data to help resolve the issue.
Reply
