Has any build an app or configured Degree Decimal Minutes for Arcgis Online
4293
01-18-2016 01:14 PM
ColeBrown1
Has any build an app or configured Degree Decimal Minutes for Arcgis Online. I am using a basic web application -  the Widget Coordinate once you enter the WKID and select the Display Units - The only options for Lat and Ling is Decimal Degree and Degrees, Minutes and Seconds. Why is there not the option for Degrees Minutes and Decimal Minutes?? Most Aircraft GPS units only use this format of Degrees Decimal Minutes.
Also Why is there not an option to name the Display units - It only shows the Output coordinate system - So if you have two and use the drop down arrow you do not know which unit is which if the display shows the WKID.
Also on the Web map why can't there be dual display of coordinates which in Search and Rescue we use USNG and Lat/Long in Degree Decimal Minutes.
Thanks
Cole Brown, (410) 404-8962 or Colesar@Comcast.net
DanPatterson_Retired
probably because no one has put in a suggestion to ArcGIS ideas or posted a provide feedback comment to places in the online help topics for arcgis online that deal with coordinates. And... if you can't find examples here, then you could search/keep an eye on ArGIS Scripts (beta) Search ArcScripts (BETA)
