Power Bi - Showing coordinates as lines instead of dots/ points
1612
10-15-2019 12:37 PM
paritoshpendse
Hello,
I work for a pipeline installation company and I wanted to plot the progress using ArcGis. While my data set have coordinates and different installation phases, all I can get are the dots plotted on Maps. I would like if I could change these dots in the form of Lines or dashes would be great. Also If I could specify the widths of individual phases will be of great use to define Right of Way etc.
Attached is the picture, below is the ArcGis and above is showing some another Visualization
Any help in this regards will be highly appreciated
Matthew_Ballard
The ArcGIS maps for PowerBI plug in does not allow for you to create lines.
If you publish your pipeline data to your ArcGIS Online, you can add the layer to your map as a reference layer or as a basemap.
This would be the better route because you could define the symbology in the web map meeting the requirements of specifying widths and it would support points, lines, and polygons.
You could then layer in your points later if you want to create visuals/charts from the data.
