WFS: attribute request
1628
09-21-2010 11:49 PM
PierreLACROIX
From SDE data in WGS 84, I would like to execute a WFS request in order to get the rivers with rank 1 on an area defined by a BBox.
The following request works (all rivers) :
http://<my server>/arcgis/services/WFS_SDE/MapServer/WFSServer?bbox=1,40,5,50&styles=&request=GetFeature&version=1.0.0&srs=EPSG:4326&typename=WFS_SDE:river
If I had the attribute, it does not work anymore (only rivers with rank = 1; river_rank is the name of the field) :
http://<mon serveur>/arcgis/services/WFS_SDE/MapServer/WFSServer?bbox=1,40,5,50&styles=&request=GetFeature&version=1.0.0&srs=EPSG:4326&typename=WFS_SDE:river&river_rank=1
I have tested a lot of different syntaxes, without success.
Does someone have an idea?
Thank you in avance.
Piotr
PierreLACROIX
Hi everyone,
Here is an example of "attribute request" returning the rivers with cntry_name = Switzerland:
http://sdi.unige.ch/arcgis/services/WFS_GDB/MapServer/WFSServer?styles=&request=GetFeature&version=1...<ogc:Filter><ogc:PropertyIsEqualTo><ogc:PropertyName>cntry_name</ogc:PropertyName><ogc:Literal>Switzerland</ogc:Literal></ogc:PropertyIsEqualTo></ogc:Filter>
Piotr
MikeMcMahon
Before you go all crazy and specific, have you tried a huge BBOX?
bbox=-180,-90,180,90
I had a case where my data didn't show up because the window afforded by the BBOX didn't match where my data was being displayed (X and Y coordinates had been reversed and my data was in a different hemisphere).
PierreLACROIX
Yes, I have checked that.
And finally I have posted the answer.
Thank you anyway for your help.
Piotr
