Default CRS used by WMS
4814
02-10-2014 04:39 AM
jorisfrenkel
Occasional Contributor II
I am still using ArcGIS suite 9.3.1.
When viewing a WMS service from ArcGIS Server in ArcGIS Desktop, the default CRS used is CRS:84. Since it is a mapservice with many layers, and the crs of the dataframe is not CRS:84, the request takes a long time to complete, around 100 seconds. And although there are no errors in the log file, the map image is not displayed. The CPU of the ArcGIS Server machine is on 100% for all that time.
Only when setting the coordinate system of the dataframe first (to the coordinate system of the dataframe the mapservice uses), it displays, and it displays fast.
Is there a way to change the default CRS of the mapservice from CRS:84 to the CRS used by the original dataframe?
TIA,
Joris Frenkel, Staatsbosbeheer, the Netherlands
NguyenTuan
 Hi Joris Frenkel
I am using ArcGIS Server 10.3 and I am facing with the same problem as you did. I would like to know if you solved the issue? Would you mind to share the solution with me?
Thanks
