This map provides a visual analysis of energy efficient construction in Kenton County. It focuses specifically on two energy efficient construction programs, Leadership in Energy & Environmental Design (LEED) and the Home Energy Rating System (HERS) Index. LEED is a credit-based certification system in which projects earn points for including various means of efficient design. HERS uses an index score in order to compare a home’s energy efficiency to a baseline home, and is a nationally-recognized scoring system.
The map shows locations of LEED and HERS projects along with a density analysis designed to identify clusters—or ‘hot spots’—of energy efficient construction. HERS projects were constructed between 2012 and 2014 inclusive. Non-HERS-rated residential construction that meets 2009 International Energy Conservation Code standards or better is not shown since it is now mandated across the state.
This map represents the first in a series of maps for the NKYmapLAB initiative. The initiative seeks to accomplish two critical goals: illustrate the robust analytical capabilities of LINK-GIS; and, use those capabilities to support Kenton County’s economic development program.
Northern Kentucky mapLAB will produce and distribute maps on a monthly basis using data supplied by LINK-GIS, and other featured data sources, as appropriate. Future maps will focus on a number of issues critical to economic development including quality of life.
LEED is a credit-based certification system in which projects earn points for including various means of energy efficient design. HERS uses an index score in order to compare a home’s energy efficiency to a baseline home, and is a nationally-recognized scoring system.
The map shows locations of LEED and HERS projects along with a density analysis designed to identify clusters—or ‘hot spots’—of energy efficient construction. HERS projects shown on this map were constructed between 2012 and 2014 inclusive.
See all of the NKYmapLAB work at the following link LINK-GIS | NKYmapLAB
