LiDAR data are used extensively for multiple purposes, either in their native format or as derivative products. LiDAR is an acronym for “Light Detection and Ranging.” Similar to RADAR (Radio Detection and Ranging) which uses radio waves, LiDAR uses light wave pulses to measure distance.
LiDAR is used primarily to measure distance. When used in airborne mapping (mounted in a plane), LiDAR can measure the topography of the ground. LiDAR uses a light scanning instrument that emits, and then records, the return of infrared light pulses at a rate of 100,000 to 400,000 times per second.
Here is a brief overview of how that process works.
Not only are LiDAR data used in GIS and mapping, they form the basis of several important base layers used frequently in them. LiDAR is used typically to create digital elevation models (DEMs), hillshade layers, and topographic contour lines. It is also used to detect landslides and even to extract automated features (identifying objects such as buildings).
LINK-GIS has over 75 GB of LiDAR data for Kenton County. The data cover all 164 square miles of the county, the product of flights from 2007 and 2012. The total number of LiDAR points in the 2012 data set is roughly 1,700,000,000 (1.7 Billion). Each point represents an X, Y, and Z value (latitude, longitude, and surface elevation).
Preliminary scheduling is underway for a county-wide LiDAR update in 2018 or 2019.
