Hello to all:
I need to download ArcMap 10.2. Does anyone have a recommendation on the best way to do this or where to go to get a clear step by step process for doing this? I have a code from my professor for downloading a student licence.
Mel
Hi Melvin,
If the code will work with 10.4, then you can get a "trial" version from Esri's site, here:
ArcGIS for Desktop | Free Trial
Otherwise, your professor should have an install DVD that has ArcGIS 10.2 on it (or at least I would hope).
Thanks Adrian for the information. I will look into this.
Best
Sent from my Galaxy Tab® A
Your professor is the point of contact for software, or you library perhaps. The education version distributed through an educational institute is maintained and supported by them. So as a minimum, find out the contact person there through your professor they are not the one.
And as indicated, you should check to see why they aren't using at least 10.3.1. It is highly unlikely that 10.4 is being distributed quite yet, but I wouldn't install any version higher than the one your institution supports or has installed since you will run into a whole load of other issues.
Thanks Dan for your suggestions. I do appreciate them.
Best
