stuck on the route editing tool. When I try to use make route, it states that there are no acceptable targets
4810
5
06-04-2016 11:48 AM
gregtides
Hello! I am biologist who has been teaching himself how to use arcmap. My place of employment just gave me a simple task, create a map of a river, and find distances between sites that were sampled along the river. They provided written instructions, and I would like to complete the task over the weekend. ' Right now I am stuck on the route editing tool. When I try to use make route, it states that there are no acceptable targets, make route creates m aware polylines. Can anyone provide me the solution to this problem? I acquired flowline data from NHD, which I have been using as the base for my map.
TedKowal
Honored Contributor
Making routes is pretty basic....  when issuing the make route command do you have the set of polylines selected? (ones that will become the route)
gregtides
Thank you, your advice was wasn't helpful with my problem, but I appreciate
that you at least took the time to engage with a novice at Arc. I figured
the issue out on my own eventually.
Thank you for your time.
Geoff
TedKowal
Honored Contributor
I am sorry and from your description of your problem, I do not know where you are stuck?  Typically, when I get summer interns and they try and create routes (m aware lines); it is because they do not have a line segment selected upon which to create the route (most common type of problem).
ESRI does have help here: About using ArcMap to create routes from existing lines—Help | ArcGIS for Desktop   From my interpretation of your problem you are trying to create routes(m aware line)  based upon the rivers linework.
Hope this helps you figure it out!
gregtides
I figured out my issue when I was able to get into the lab and pull up some
of their existing data. While I was working on my program at home I was
working with a polyline shapefile that I found myself on the usgs website.
I suspected that was part of my issue, since it was specifying m awareness
in the error message. When I worked on arc at my lab I was using polyline
zm data, that seemed to fix the problem that I was running into. Looking
back I might have able to circumvent the problem if I tried creating a
route with the data I pulled from the internet using create routes in the
linear referencing tools. I was pretty zeroed in on following the
instructions that I was given from my supervisor though, and it wasn't till
I was exploring the zm polyline shapefile that it occurred to me to that I
hadn't tried that.
Sorry if the previous message was vague, I appreciate this dialogue, and I
am really excited to be making and using a map form data that I collected!
This has been a personal goal for a long time, since arcgis started showing
up on job fliers a lot after I graduated form college.
Geoff
TedKowal
Honored Contributor
Sometimes working out the problem for your self is the best path in learning.
I generally use create routes from the linear referencing tools and my comments where under the assumption you were doing the same.  I am glad you were able to resolve your problems.
