Remove a callout or point added with the "Go to XY" tool
25245
6
10-01-2014 11:53 AM
ThomasCaruso
Hi folks. This is a really basic question, I know, but I can't for the life of me figure it out. I accidentally added a callout with the go to XY tool and cannot remove it. I have searched all over online and in the ArcGIS help page and haven't found anything. Anyone know how to do this?
Thanks in advance,
Tom
Tags (3)
TimWitt2
Thomas,
Those are added to the map as a graphic, you should be able to select them with the select elements arrow and delete them.
Tim
TimWitt2
Thomas,
Tim
ThomasCaruso
Many thanks - this was really bugging me. Cheers!
TimWitt2
No problem! I had the same issue once and it was really annoying!
WhitneyMarshall
Where do I fin the select elements arrow
FAZLIANAMUSTAJAP
I have the same issue here. I put the xy pin and I want to remove it. But I have no idea how to do it. If in ArcGIS, we just click on that pin and delete it. But in ArcGIS pro, i dont know how it's working.
Bud
Esteemed Contributor
I noticed that the pins are a bit buggy. They become misaligned when you pan around in the map.
The issue is especially obvious when I use the Select All tool in the Graphics bar in the ribbon. When I select the pins (graphics), the bounding boxes/selections are misaligned with the pins. So that confirms that the pins have alignment issues.
Has anyone else noticed that issue?
