How to reduce maximised Table of Contents window Desktop 10.1?
4364
01-07-2015 08:26 AM
PeterSchlesinger
I have 10.1 and my Table of Contents window has fully maximized across my entire screen (see attached jpg) and I cannot figure out how to reduce it; I cannot select a right edge of the frame nor the corner of the window to drag it back. How to fix this? Thanks much. Peter
XanderBakker
Esri Esteemed Contributor
Simply drag the window;  locate the mouse on the blue title bar, drag the window until you see the anchor points appear and locate the window for instance to the center left anchor to make it appear as the left column of the window.
PeterSchlesinger
Thanks so much, Xander! I knew it had to be something easy, but it was not documented anywhere I could find.
Best
Peter
