How to create a map which displays the highest value in each row?
3797
03-10-2015 10:34 AM
JackHeron
I'm currently attempting to display the NS-SEC values for the year 2001 in London, and wish to display which sector type has the highest value in each of the Output Areas, but as I'm an amateur with Arc GIS, I cannot figure out how to accomplish this.
ZONE_CODEKS14A0002KS14A0003KS14A0004KS14A0005KS14A0006KS14A0007KS14A0008KS14A0009
00BEGS0001514331889257
00BEGS0002315271811113420
00BEGS0003917353313153827
00BEGS00047536259132515
00BEGS000535242310132630
00BEGS00066923175122015
00BEGS0007184056101181413
For example, how would i display on a map for zone "00BEGS0001" that field "KS14A0004" contains the highest value?
Thanks for your help
KishorGhatage
Please refer field calculator expression given by dhoneycutt-esristaff in  the below discussion:
Find maximum value across a row
After having all the max value's field name  in a new field, you can use it to label the zones or set symbology.
Hope this is helpful
Regards
Kishor
