How do I get my data to show together
4764
13
03-05-2016 10:19 AM
CaroleWacta
I have a point file and boundary file that are all projected to the same projection...
Except that I cannot see them together. each file shows up if I do ZOOM to LAYER, but not on the same screen.
What am I missing? I have attached both files
Thank you.
C
JayantaPoddar
If they are meant to overlap, check the extent of both the layers. One of them should be defined a different coordinate system.
Could you mention the extent of both the layers and their projection system?
Think Location
CaroleWacta
I will check that...
Where do I find the extend? in the properties?
Thank you
CaroleWacta
they have different extend...
How do I change that?
Thank yiu
JayantaPoddar
I don't have an access to any GIS software. If the extent of a shapefile is between 0-180, you need to define a geographic coordinate system (e.g. GCS_WGS_1984)
In ArcCatalog, right-click the shapefile and go to its properties. Edit the spatial reference and define a different coordinate system to check if it falls correctly on Map.
Think Location
CaroleWacta
JayantaPoddar
The traffic data is defined a wrong projection.
From ArcCatalog, go to its properties, and edit the spatial reference to Geographic Coordinate System > World > WGS 1984.
Else you could also define it as GCS_North_American_1983.
Check for the more appropriate coordinate system.
Think Location
JayantaPoddar
Since your current projection system is derived from GCS_North_American_1983, I would try this one first.
Think Location
CaroleWacta
I see it.
Thank you...
I will try that.
C
CaroleWacta
Hello, I can see  the second and thirds together, but not the first... Why will this one not show in the window with the two below? they seem to have the same coordinates??
