Changing the start point of linear features
3588
08-18-2015 08:32 AM
DavidFunchall
Hello all
i am working on an asset model for a large drainage system that uses points to represent certain features which are joined by lines. the upstream point features periodically move as a result of system reconfiguration or re-survey which necessitates the re-snapping of the linear features to them.
Is there any way I can do this without having to edit each line individually? ie is there any way I can simply batch-update the XandY values for the line start points?
Many thanks in advance!
DanPatterson_Retired
Not without writing code. You would have to weight the time necessary to do that versus the time you spend performing this task.  There is nothing in the Editing toolbox An overview of the Editing toolbox—Help | ArcGIS for Desktop
