Xamarin version 100.1 displayfield for layer from ArcGISMapImageLayer
1434
01-10-2018 02:01 PM
GregorySayre
In version 100.1, is there a way to get the display field for a layer in an ArcGISMapImageLayer?  It's connecting and drawing fine and I can view ALL the fields for a feature, but I don't know which field is the DisplayField.
var dynamicMapUrl = new Uri(SettingHelper.GisSettings.MapServiceUrl);
dynamicLayer = new ArcGISMapImageLayer(dynamicMapUrl) {Opacity = Constants.EsriMap.DynamicLayerOpacity};
_map.Basemap.BaseLayers.Add(dynamicLayer);
// Make sure that layer and it's sublayers are loaded
await dynamicLayer.LoadAsync();
                // step through the map layers and save current visibility
foreach (ArcGISSublayer baselayer in dynamicLayer.Sublayers)
                    MapLayerViewModel parentLayer = new MapLayerViewModel();
                    parentLayer.Id = baselayer.Id;
                    parentLayer.Text = baselayer.Name;
                    parentLayer.IsSelected = baselayer.IsVisible;
                    //parentLayer.DisplayField = ?????????? //HOW DO I GET THIS?
GregorySayre
I figured out a way to load the DisplayFieldName from the dynamic layers.  I had to load information for EACH layer individually though.
In case anyone else gets stuck on this: (this only does parent and one level of child layers)
                foreach (Esri.ArcGISRuntime.Mapping.ArcGISSublayer sublayer in dynamicLayer.Sublayers)
                        String S = sublayer.DefinitionExpression;
                        await sublayer.LoadAsync();
                        String displayFieldName = sublayer.MapServiceSublayerInfo.DisplayFieldName;
                        foreach (Esri.ArcGISRuntime.Mapping.ArcGISSublayer sublayer2 in sublayer.Sublayers)
                            await sublayer2.LoadAsync();
                            String S2 = sublayer2.DefinitionExpression;
                            String displayFieldName2 = sublayer2.MapServiceSublayerInfo.DisplayFieldName;
