Xamarin UWP Map displays White sporadically after returning to page
4784
11
10-27-2019 04:11 PM
RyanReams
When using Esri ArcGIS .net version 100.6, Xamarin UWP shows a blank page on the map when coming back from a previous page.  I have tried previous suggestions of disabling MapView.LocationDisplay.IsEnabled when leaving the page, and re-enabling MapView.LocationDisplay.IsEnabled after coming back to the page.  I have seen others mention that this is occurring for them, but there doesn't seem to be a valid fix listed anywhere through.
See attached gif for behavior example
Riyasdsrc
I am also facing this issue particularly with Xamarin UWP, did you find the solution or a workaround to fix this bug.
KavitaPandey
no, i did not find any solution for this yet.
