Unable to view map when I used my company network. I thought some URL's has blocked by my company network. Could you please let me know which URL's going to hit when I use ArcGIS SDK maps?
1902
12-20-2016 10:50 PM
sarithapingili
I'm developing maps using ArcGIS SDK and Xamarin.Android.
AnttiKajanus1
It all depends what services you are using in your application. Could you describe a bit more which services you are using?
sarithapingili
Hello Antti Kajanus,
I’m using the below code to display the current location
MapView _myMapView = new MapView();
Map _myMap = new Map(Basemap.CreateImagerywithLabels());
_myMapView.Map = _myMap;
_ myMapView.LocationDisplay.AutoPanMode = LocationDisplayAutoPanMode.Recenter;
if (!_myMapView.LocationDisplay.IsEnabled)
_ myMapView.LocationDisplay.IsEnabled = true;
If I’m using my personnel network, I can able to view but I’m unable to view with my company network.
When I try to browse arcgis related sites I can able view using my company network.
Please give me the solution.
Regards,
Saritha
dotMorten_esri
Esri Notable Contributor
Loop through Source Uri property on the the layers created with the CreateImageryWithLabels() call, and you will see what gets called.
MaraStoica4
Could you look at the traffic from your application? What sites is it trying to reach, and what errors are you getting? You could use a tool like Fiddler to look at network traffic.
