Polygon areas label are set to 0,0 lat,lon
255
03-17-2022 01:22 AM
GonzaloMuñoz
New Contributor II
Hi all,
we have some polygons (rectangles) in our map with a labeldefinition like :
labelBuilder.AppendLine("{");
// Define a labeling expression that will show the Name attribute value
labelBuilder.AppendLine("\"allowOverrun\": true ,");
labelBuilder.AppendLine("\"allowOverlapOfLabel\": \"allow\" ,");
labelBuilder.AppendLine("\"allowOverlapOfFeatureBoundary\": \"allow\" ,");
labelBuilder.AppendLine("\"allowOverlapOfFeatureInterior\": \"allow\" ,");
labelBuilder.AppendLine("\"priority\": 25 ,");
labelBuilder.AppendLine("\"labelExpressionInfo\": {");
labelBuilder.AppendLine("\"expression\": \"return $feature.Name;\"},");
// Align label horizontally
labelBuilder.AppendLine("\"labelPlacement\": \"esriServerPointLabelPlacementCenterRight\",");
labelBuilder.AppendLine("\"multiPart\": \"labelLargest\",");
// Set the style for the text symbol
labelBuilder.AppendLine("\"symbol\": {");
labelBuilder.AppendLine("\"color\": [255,255,255,255],");
labelBuilder.AppendLine("\"haloColor\": [51,51,51,255],");
labelBuilder.AppendLine("\"haloSize\": 1.5,");
labelBuilder.AppendLine("\"font\": {\"size\": 10, \"weight\": \"bold\"},");
labelBuilder.AppendLine("\"type\": \"esriTS\"}");
labelBuilder.AppendLine("}");
and the problem we are finding is that the label is set at lat,lon 0,0. Does anyone know where is the problem?
Regards
Gonzalo
PeterDimitrov1
Hi GonzaloMuñoz,
Just to check if I understand you correctly - are you saying that all the labels for polygon features which have that label definition are placed away from the polygons at Lat/Lon 0/0 or just one label is exhibiting this behaviour?
Also, would you be able to share any data with us such as an MMPK so we can have a look (assuming you are loading from a local data source and not a web map)?
Regards,
Peter Dimitrov
