lock files remains for local geodatabase in WPF App
6653
8
10-20-2014 01:33 PM
MyronChew
After I used OpenAsync on a local geodatabase, it created these two lock files: .geodatabase-wal,.geodatabase-shm after I added some layers to the MapView.   The lock files remain even I removed all its layers or perform GC.Collect.  Is there a way to close the opened geodatabase without closing the application?
dotMorten_esri
Esri Notable Contributor
Did you also remove all references to the table, geodatabase and waited for pending finalizers?
MyronChew
Hi Nielsen
Thanks for your quick reply.
The following is my test project I pulled out from our
development.  Unloading will not release the map lock files.
My xaml markup and code are as followed:
<Window
      xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
      xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
      xmlns:esri="http://schemas.esri.com/arcgis/runtime/2013" xmlns:Custom="http://infragistics.com/DockManager" x:Class="ArcGISRunTimeTest.MainWindow"
      Title="MainWindow" Height="350" Width="525">
   <Grid>
       <esri:MapView x:Name="mapView" HorizontalAlignment="Stretch" VerticalAlignment="Stretch" MouseDown="MapView_MouseDown" MapViewTapped="MapView_MapViewTapped" MouseDoubleClick="MapView_MouseDoubleClick" KeyDown="MapView_KeyDown" Margin="0,63,0.4,0.4" ExtentChanged="mapView_ExtentChanged" MouseMove="mapView_MouseMove" PreviewMouseDoubleClick="mapView_PreviewMouseDoubleClick">
           <esri:Map>
                <esri:GraphicsLayer x:Name="graphicsLayer"
           </esri:Map>
       </esri:MapView>
       <Button Content="Button" HorizontalAlignment="Left" Height="28" Margin="49,8,0,0" VerticalAlignment="Top" Width="70" Click="Button_Click"/>
       <Button Content="Button" HorizontalAlignment="Left" Height="28" Margin="183,8,0,0" VerticalAlignment="Top" Width="79" Click="Button_Click_1"/>
       <TextBox x:Name="textbox1" Height="38" Margin="323,8,35.4,0" TextWrapping="Wrap" Text="TextBox" VerticalAlignment="Top"/>
       <Button Content="LoadMap" HorizontalAlignment="Left" Margin="49,63,0,0" VerticalAlignment="Top" Width="75" Click="Load_Click"/>
       <Button Content="unLoadMap" HorizontalAlignment="Left" Margin="183,63,0,0" VerticalAlignment="Top" Width="79" Click="Unload_Click" RenderTransformOrigin="1.987,0.454"/>
   </Grid>
</Window>
private async void Load_Click(object sender, RoutedEventArgs e)
           if
(!mapView.IsInitialized)
return;
mapView.Map =
new Map()
InitialViewpoint =
new Viewpoint(new Envelope(-13054165, 3850112, -13027133, 3863559, SpatialReferences.WebMercator))
mapView.Map.SpatialReference =
SpatialReferences.WebMercator;
           Geodatabase gdb = await Geodatabase.OpenAsync(@"C:\Temp\H2OTEST.IWDB\Map\map.geodatabase");
           GeodatabaseFeatureTable gftable = gdb.FeatureTables.FirstOrDefault(m =>
m.Name.ToUpper() ==
"JUNCTION");
           FeatureLayer myFeatureLayer = new Esri.ArcGISRuntime.Layers.FeatureLayer(gftable);
mapView.Map.Layers.Add(myFeatureLayer);
            gftable
= gdb.FeatureTables.FirstOrDefault(m => m.Name.ToUpper() ==
"PIPE");
mapView.SetViewAsync(myFeatureLayer.FullExtent);
myFeatureLayer =
       private void Unload_Click(object sender, RoutedEventArgs e)
         mapView.Map.Layers.Clear();
System.
GC.Collect();
           GC.WaitForPendingFinalizers();
ArtemHmara
Did you find out solution for this issue?
ReedHunter
I ran into this problem, and the WaitForPendingFinalizers clue helped me to solve this.  I have a .Net app for downloading a geodatabase, acquiring and writing to the geodatabase some attributes from an external sql server database, syncing edits back if necessary to the feature service, and then zipping the offline geodatabase.  The geodatabase openasync however would hold a lock on the .geodatabase file, preventing the zip from working.  The solution was to structure my program this way ...
        static void Main()
            var gdbPath = "";
            Task.Run(async () =>
                //omitting code for downloading geodatabase asynchronously, and other operations on the file
            }).Wait();
            GC.Collect();
          //code to zip the geodatabase
Hope this helps anyone else who comes across this problem.
PhilScovis
I've had this problem too; This thread claims that it is a known bug.
In my case, I'm trying to re-create a .geodatabase from the server.  I can remove the existing layer from the map view, but there's no way to dispose it.
My workaround was to use a new filename for the new file.  I check for old files when the application starts, and try to delete them.  This is not ideal, because the old file will remain in the filesystem until the application restarts.
AnttiKajanus1
You can use Geodatabase.Close Method  to close the geodatabase so all the locks are released.
PhilScovis
That worked; thank you!
PhilScovis
Is there an equivalent for a .tpk file that is being held open by a Tiled Layer?
