Is it possible to use the .NET runtime SDK to query multiple layers of a feature service at once?
4632
04-16-2015 08:24 AM
meme2
I'm looking to use the Feature Service Query API, and query multiple layers at once.
So, building off the example on the query API page, I want the query to look something like this:
http://<featureservice-url>/query?layerDefs=[{"layerId":<layerDef1>},{"layerId":<layerDef2>}]&geometry=<geometry>&f=json
And I can't seem to be able to figure out how to get that through the .NET runtime SDK (without resorting to using an ArcGISHttpClient).  Any suggestions?
MichaelBranscomb
Esri Frequent Contributor
The QueryTask class works against a single layer in a service, whereas the IdentifyTask and FindTask work against multiple layers in a service. It sounds like you might be able to use the IdentifyTask in your case, to provide a geometry filter which will return all features in layers from the service which intersect the geometry?
- Samples for the query task classes (Find / Identify / Query): arcgis-runtime-samples-dotnet/src/Desktop/ArcGISRuntimeSDKDotNet_DesktopSamples/Samples/QueryTasks a...​​
- API ref for the Tasks.Query namespace (Esri.ArcGISRuntime.Tasks.Query Namespace).
Depending on your exact workflow, you might also like to look at the ServiceFeatureTable Query method: ArcGISFeatureTable.QueryAsync Method (QueryFilter)
Cheers
Mike
meme2
Thanks Michael!
With the IdentifyTask, can I return certain fields along with the feature (like the outFields query parameter)?  I'm looking to pull in a bunch of data from a feature service as quickly as possible.  So, I'd rather not query every layer individually.  Plus, I need certain fields on the features returned.
I did write a quick wrapper around the feature service query:
    public class QueryEntry
        private readonly int _layerId;
        private readonly string _whereClause;
        private readonly string _outFields;
        public QueryEntry(int layerId, string whereClause, string outFields)
            _layerId = layerId;
            _whereClause = whereClause;
            _outFields = outFields;
        [JsonProperty("layerId")]
        public int LayerId { get { return _layerId; } }
        [JsonProperty("where")]
        public string WhereClause { get { return _whereClause; } }
        [JsonProperty("outFields")]
        public string OutFields { get { return _outFields; } }
    public class QueryOperation
        private readonly IEnumerable<QueryEntry> _queries;
        private readonly Esri.ArcGISRuntime.Geometry.Geometry _geometry;
        private readonly SpatialReference _inSpatialReference;
        private readonly SpatialReference _outSpatialReference;
        public QueryOperation(IEnumerable<QueryEntry> queries,
            Esri.ArcGISRuntime.Geometry.Geometry geometry = null,
            SpatialReference inSpatialReference = null,
            SpatialReference outSpatialReference = null)
            _queries = queries;
            _geometry = geometry;
            _inSpatialReference = inSpatialReference;
            _outSpatialReference = outSpatialReference;
        public override string ToString()
            var edits = JsonConvert.SerializeObject(_queries);
            var options = new StringBuilder();
            if (_geometry != null) { options.Append(String.Format("&geometry={0}&geometryType=esriGeometry{1}", _geometry.ToJson(), _geometry.GeometryType)); }
            if (_inSpatialReference != null) { options.Append(String.Format("&inSR={0}", _inSpatialReference.ToJson())); }
            if (_outSpatialReference != null) { options.Append(String.Format("&outSR={0}", _outSpatialReference.ToJson())); }
            return String.Format("layerDefs={0}{1}&f=pjson", edits, options);
And then it can be used like this:
var client = new ArcGISHttpClient();
var queryEntries = new List<QueryEntry>();
// Generate QueryEntries
var queryOp = new QueryOperation(queryEntries, geometry);
var content = new StringContent(queryOp.ToString());
content.Headers.ContentType = new MediaTypeHeaderValue("application/x-www-form-urlencoded");
var result = await client.PostAsync(service.Uri + "/query", content);
var json = await result.Content.ReadAsStringAsync();
That seems to give me what I want, but it feels like I'm rewriting something that already exists in the .NET runtime SDK.
