Esri Map appears blank on Maui, but still shows "Powered by Esri" tag at the bottom
944
08-02-2023 08:29 AM
Labels (3)
cdirth
Getting a weird interaction where the Esri map shows up as pure blank white. The odd thing is that the "Powered by Esri" tag is still at the bottom, and when I adjust the size of the MapView control at runtime, that blank white turns to an empty gray. This is happening on both emulator and actual device. Please help soon, we have an upcoming release and this is blocking the android side. (Weird thing is Windows and iOS is totally fine)
AndyWeis
Hi @cdirth, could you please provide the code in your xaml and xaml.cs files that you're using to run this application so I can attempt to reproduce this?
JoeHershman
MVP Alum
The description makes it seem like no layers are getting loaded
-Joe
