Hi, I've run into a problem where our app is running accross multiple devices, however it crashes at startup on a Xiaomi Redmi 9AT, Android 10, API 29. I have been able to track the crash to the MauiProgram.cs at builder.UseArcGISRuntime() and it only crashes on the ArcGISRuntime SDK version 200.5 and onwards.
Below are the code where the crash happens (line 4) and the Device Log (logcat)
var builder = MauiApp.CreateBuilder();
builder
.UseMauiApp<App>()
.UseArcGISRuntime()
.ConfigureFonts(fonts =>
fonts.AddFont("OpenSans-Regular.ttf", "OpenSansRegular");
fonts.AddFont("OpenSans-Semibold.ttf", "OpenSansSemibold");
});Time Device Name Type PID Tag Message
12-03 17:11:55.081 Xiaomi M2006C3LVG Error 29988 AndroidRuntime android.runtime.JavaProxyThrowable: System.InvalidProgramException: Invalid IL due to: method RuntimeCoreNet.GeneratedWrappers.CoreArcGISRuntimeEnvironment:OnPrivateArcGISRuntimeEnvironment_ArcadeConsoleMessage (intptr,intptr,RuntimeCoreNet.GeneratedWrappers.CoreInteropString) with UnmanagedCallersOnlyAttribute has non-blittable parameters or return type assembly:<unknown assembly> type:<unknown type> member:(null)
at RuntimeCoreNet.GeneratedWrappers.CoreArcGISRuntimeEnvironment.SetArcadeConsoleMessageCallback(CoreArcadeConsole_MessageReceived )
at Esri.ArcGISRuntime.ArcGISRuntimeEnvironment.InitializeRuntimeCore()
at Esri.ArcGISRuntime.ArcGISRuntimeEnvironment.Initialize(Action`1 )
at Esri.ArcGISRuntime.Maui.AppHostBuilderExtensions.UseArcGISRuntime(MauiAppBuilder builder, Action`1 configure)
at Esri.ArcGISRuntime.Maui.AppHostBuilderExtensions.UseArcGISRuntime(MauiAppBuilder builder)
at MauiAppXiaomiTest.MauiProgram.CreateMauiApp()
at MauiAppXiaomiTest.MainApplication.CreateMauiApp()
at Microsoft.Maui.MauiApplication.OnCreate()
at Android.App.Application.n_OnCreate(IntPtr jnienv, IntPtr native__this)
at Android.Runtime.JNINativeWrapper.Wrap_JniMarshal_PP_V(_JniMarshal_PP_V callback, IntPtr jnienv, IntPtr klazz)
at crc6488302ad6e9e4df1a.MauiApplication.n_onCreate(Native Method)
at crc6488302ad6e9e4df1a.MauiApplication.onCreate(MauiApplication.java:28)
at android.app.Instrumentation.callApplicationOnCreate(Instrumentation.java:1189)
at android.app.ActivityThread.handleBindApplication(ActivityThread.java:6603)
at android.app.ActivityThread.access$1500(ActivityThread.java:235)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1916)
at android.os.Handler.dispatchMessage(Handler.java:107)
at android.os.Looper.loop(Looper.java:225)
at android.app.ActivityThread.main(ActivityThread.java:7563)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:539)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:994)
We unfortunately cannot go back to the SDK version 200.4, because version 200.5 fixed a breaking issue for us where the map would turn blank when the app had been running in the background for a while.
Reproduction
Running the app on a Pixel 5 Android 10 API 29 emulator device does not result in a crash.
Running the app on the Xiaomi Redmi 9AT with ArcGISRuntime SDK version 200.4 does also not result in a crash.
I have not been able to test the app on other Xiaomi devices or other Android 10 API 29 devices.
If there any remaining questions, please let me know.
Solved! Go to Solution.
Thanks @dotMorten_esri . I have updated app and will try to upload to store.
