What is the difference between ArcGIS Pro and ArcGIS online
155
6
10-27-2020 07:12 AM
New Contributor II
I have used ArcGIS Pro and i want to use ArcGIS no. So can anyone please tell me the difference between the both ?
Tags (1)
Reply
Esri Notable Contributor
I'd start by reviewing ArcGIS Pro | 2D and 3D GIS Mapping Software  and ArcGIS Online | Cloud-Based GIS Mapping Software for an overview of each.  It sounds like you've worked with ArcGIS Pro, so should have at least some familiarity with that.  Basically, Pro is desktop software that is installed on a machine (physical desktop, laptop, or VM) while ArcGIS Online is a software-as-a-service (SaaS) offering.  For further, specific questions, you could ask in either the ArcGIS Pro or ArcGIS Online GeoNet spaces.
Hope this helps!
Hope this helps!
New Contributor II
Yes I know that ,  I just wanted to know that all the tools and functionalities available on the ArcGIS Pro and Online are the same or there is some difference ?
Reply
Geoprocessing, editing, cartography, etc. capabilities are far more extensive in ArcGIS Pro than ArcGIS Online, so depending on the work someone needs to accomplish, one of the two may be better suited to meet their needs - or very commonly, users leverage capabilities of both Pro and Online!
New Contributor II
Ok thanks alot. I am just gonna explore the ArcGIS more. I am planning to get a course to learn more of ArcGIS so that i get a better job opportunity. I am just a beginner to it and the ArcGIS online would be a affordable option for me?
Reply
For learning, Learn ArcGIS  is a great place to start.  You can use a trial for learning purposes, and there is also ArcGIS for Personal Use for Noncommercial GIS Projects that could be a good fit for you for learning purposes.
New Contributor II
Ok. Thanks alot. I am also planning to take the ArcGIS online subscription after learning this. Will that be a good option?
Reply
