Download earlier versions of ArcGIS Desktop
3973
04-03-2019 06:11 AM
GregKrause
How and where do I download earlier versions of ArcGIS for desktop, specifically 10.3.x?
ManuelBallesteros
New Contributor III
Hi Greg – I worked with our team and you should now have access to the 10.3 version. Can you please check?
Manny Ballesteros | Customer Service Team Lead
Esri | 380 New York St | Redlands, CA 92373 | USA
T 909 793 2853 x 2240 | mballesteros@esri.com<mailto:mballesteros@esri.com> | esri.com<http://esri.com/>
THE SCIENCE OF WHERE ®
ManuelBallesteros
New Contributor III
Hi Greg – if you are eligible, it would be on the My Esri site. There is a drop down showing 10.4.1 most likely and you can select 10.3 from the drop down menu.
GregKrause
That is interesting, I actually don't have the dropdown menu option that enables me to select earlier versions, only the 10.7 download. Sounds like I will need to contact ESRI more directly.
ManuelBallesteros
New Contributor III
GregKrause
I checked this morning, and yes the earlier versions are now available via a drop down menu. Perfect, that was quick, thank you.
