GIS Dictionary Supplement with ArcGIS Pro Terminology
948
09-12-2020 09:36 PM
Status: Open
LuciaBarbato1
New Contributor III
The current GIS Dictionary, Esri Support GIS Dictionary, references ArcMap terminology (i.e. data frame, map document, ArcMap, data view, etc.), however, ArcGIS Pro uses different terms (map frame, project, ribbon). In the dictionary, where definitions reference [Esri Software] it would be helpful to differentiate ArcMap vs ArcGIS Pro software terminology.
3 Comments
KoryKramer
Hi Lucia.  Thank you for submitting this idea.  I'll check in with the team that maintains that online dictionary to see about updating it.  In the meantime, hopefully https://www.esri.com/library/brochures/pdfs/arcgis-pro-terminology-guide.pdf  will help.
Cheers
LuciaBarbato1
Hi Kory,
Thanks for the quick reply and for referring the suggestion to the documentation team.
I have found the arcgis-pro-terminology-guide.pdf very helpful when I was (and continue to) transitioning to Pro.
Keep up all the great work that you do.
Hope you have a wonderful week.
Lucia Barbato, GISP
Instructor, Dept. of Geosciences
Sr. Research Associate, Ctr. For Geospatial Technology
Texas Tech University
806.834-8999
KamB
Thank you for your post. The Esri Support GIS Dictionary is a great resource. I hope Esri continues to maintain the old material that references ArcMap, as they build out support for ArcGIS Pro. I use ArcMap everyday at work, and many other companies still extensively use the software.
