I am trying to add a "Select by Attribute" tool to my model and have done so in the past. However, I am using an ArcEditor license in version 9.3.1 and this may be a versioning issue as I was previously using an ArcInfo license.
I don't want to use the "Select Layer by Attribute" nor the "Feature Class to Feature Class" tools because I will need to use them more than ten times throughout the model and it will a lot of work for me in the long run.
Does anyone have an answer, or a workaround, for this issue? Having this model will save me a day's worth of work every quarter!
Thank you in advance for your help!
