Modelbuilder problem - spatial join and then select
831
08-18-2014 08:38 AM
MarcusHumphrey
trying to create a spatial join that then selects, however keep getting results with no records, and there should be records. when run the two tools seperately get results. Any help appreciated.
NaimeCelik
You may want to check your match option in your spatial join maybe, the option you select is not giving any result.
MarcusHumphrey
It now works, was no obvious reason why it didn't.
