Model Builder batch clip using multiple clip features
808
03-17-2021 02:12 AM
PaulRobinson5
Hi all,
I have created an iterator model to batch clip feature classes by one clip feature, but ideally I want to clip the same feature classes from one gdb by multiple clip features, for example, shapefiles of regions 1-3 and export the outputs to three separate gdb's in one model as apposed to running the same model three times for each clip region. Is this possible, either using Model Builder (in ArcMap) or by using arc.py? Any help would be greatly appreciated.
Thanks.
DavidPike
MVP Frequent Contributor
you can connect multiple tools to a single input data source - in this case 3 clip tools connected to the FC. unless I'm completely misunderstanding.
PaulRobinson5
Perfect, thanks. I'll try that.
