Connecting multiple Collect Value outputs to Cell Statistics + ModelBuilder ArcGIS10.1
3956
02-24-2015 12:56 AM
JustinGleeson
I have developed a model that collects values through a number of integrated sub-models. I was hoping to use Cell Statistics to run an analysis on the results from each of the sub-models. It will work properly when I have Output Values from one of the sub-models connected but I can't seem to connect the results from more than one model.
For instance, I have the results from ModelSoils connected but can't connect ModelEnv at the same time. I have tried connecting and selecting 'Input rasters or constant values' but it won't connect.
Any suggestions on what I am missing here? Thanks Justin
JustinGleeson
Hi Vandana,
Both are rasters.
In any case I actually found a solution to this thanks to Hornbydd over on Stackexchange.
I connected the Output Value 1 and 2 to a new Collect Values and it worked fine for me.
Thanks for reply
Justin
JayantaPoddar
Hi Justin,
Instead of connecting with a connector, you can double-click the Cell-Statistics tool in the model builder. Then add the two Rasters (Output_Values_1 and Output_Values_2) to Input Rasters...
Hope it helps,
Jay
Think Location
VandanaRaghunathan
Hello Justin,
What is the data type of the Output Value and Output Value2? You can check that by going to the properties > data type.
Vandana
JustinGleeson
Hi Vandana,
Both are rasters.
Thanks for reply
Justin
VandanaRaghunathan
Sounds good.
Vandana
