Can a in_memory and a inline varible be combined as an output?
1785
10
05-25-2017 12:54 PM
BrianWade
In ModelBuilder I’m iterating multiple shapefiles to intersect against a single point layer, then write out using feature Class to Feature Class tool (I only want 2 columns in the output file).
I would like to have the Intersection output "in_memory" for quicker processing.
I also need to have the input polygon filename in the final output.
This works without the "in_memory"
Seeing the error message below is leading me to believe my issue is that I can't combine "in_memory" with a %name% inline variable as output of my intersect tool?
Also if I can accomplish this, won't I need to change my Feature Class to Feature Class tools input to in_memory also?
Any Help is appreciated
Thanks
Brian
NobbirAhmed
Writing to in_memory should be faster if the computer has enough RAM.
