Does anyone have a good workflow to produce a grade thickness map based on drill data, preferable a raster. Thanks!
314
04-22-2019 12:24 PM
RendyKeaten
New Contributor II
Given drill, how would you produce a grade thickness map?  Grade thickness= assay value*interval thickness.
Matthew_Ballard
Rendy,
One option here is to use Field Calculator to calculate the thickness at your discrete locations.
Then you can use one of several interpolation methods available to create the grade thickness grid and contours.
