Hello, i use ArcGIS Pro 2.6.2 and the Metadata Toolkit with Visual Studio 2017 to customize the GUI a little bit. So based on the following XML element from the metadata: metadata/mdContact/role/RoleCd@value i want to display a custom text in a label. I tried using the following XAML markup:
<Label Grid.Row="0" Grid.Column="0" Name="SomeLabelControl">
<Label.Style>
<Style TargetType="Label">
<Setter Property="Content" Value="unknown value"/>
<Style.Triggers>
<DataTrigger Binding="{Binding Source={StaticResource XmlRecord}, XPath=role/RoleCd/@value}" Value="001">
<Setter Property="Content" Value="Some Val 1" />
</DataTrigger>
<DataTrigger Binding="{Binding Source={StaticResource XmlRecord}, XPath=role/RoleCd/@value}" Value="007">
<Setter Property="Content" Value="Some Val 2" />
</DataTrigger>
</Style.Triggers>
</Style>
</Label.Style>
</Label>
How should the binding be defined? With the markup displayed above it only shows "unknown value".
Is there an official Metadata Toolkit forum available? Because i did not found any.
Regards
Christian
