I am getting this error when clicking on Description tab in ArcCatalog
software version?
does it occur in all circumstances for all files?
recent changes to your system?
I am using Windows & Professional. ArcGIS 10.1 SP1. No changes in my system.
This error happens when I click on Description tab in ArcCataloge to see the metadata or in catalog tree in ArcMap when R.Clicl on the data and click on Item Description.
This error appears for any data.
Try resetting the ArcGIS application profile, if that helps.
I tired Resetting the application profile, bu I did not work.
Might have to resort to a software repair. It looks like something has got a bit twisted.
Method 1:
Start the computer in Safe mode and check if you have the same issue appearing.
Start your computer in safe mode
http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
If computer works fine in safe mode, then follow the Method 2 and check.
Method 2:
Perform clean boot and check.
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/kb/929135
Note: After you have finished troubleshooting, follow these steps to reset the computer to start as usual. Refer step 7 in the article.
Method 3:
.Net Framework Repair.
1. Go to Control panel.
2. Choose Uninstall a program under Programs and Features.
3. Click on .net framework 4.0 client profile and then click on Repair.
4. Wait till the Repair process completes and restart the computer.
Method 4:
Run a malware scan and check if there are any threats.
http://www.microsoft.com/security/scanner/en-us/default.aspx
Note: Any data files that are infected may only be cleaned by deleting the file entirely, which means there is a potential for data loss.
Hope it helps.
BUSE İBŞİROĞLU, thank you for your help. It took me a long time to figure out what the problem was. The .net caused the error but it was not the source for the error, it was some fonts those LastWriteTime where very very big caused the error. I deleted them and the error was gone.
The article is describing the error.
https://support.microsoft.com/en-us/kb/2978135
Thanks.
